Plugs And Leads
bar
hi peeps
can someone advise me on the best plugs and leads to go for for my celica 202 3sge?
plenty of performance stuff out there but wandaring if anyone has some experiance in the best for this engine type?
help appreciated :thumbsup:
toyotas own platinum tipped plugs last alot longer than cheaper plugs of the same type . Iridium plugs are meant to be good and are alot cheaper , as for leads id stick to the toyota stock leads .
http://www.tcbparts.co.uk/ ----- service parts . NGK PLUGS .
http://www.sparkplugs.co.uk/ ------- Magnecor leads and plugs.
hi peeps
Most people told me that gen toyota leads are always the best to get however i got some leads for my gt4 from www.magnecor.co.uk and they are doing the job also if you go to fensport.co.uk or blitz.co.uk they will have some fancy expensive plugs for your car and probably leads too. Still not sure then give fensport a ring they are very clued up and could probably tell you the best ones to get. Personally i would get some NGK plugs reasonably priced and never let me down, just try and find out what heat range you will need.
