Noise When Turning Left Or Right
the666devil
My avensis 53 d4d makes noise's from the front wheels when turning while moving only.the noise sounds like a rotating humming.
I think it's the bearings but any other info would help !
Is it a big job to change them ?
Wheel bearings usually hum louder the faster you go and get louder when cornering due to extra pressure exerted on them. They will get noisier the worse they get and turn to more of a growl.
Not a job for someone without the tools or knowledge to change them.
Are you sure it's not just tyre noise?
I bet the CV joints have run out of grease hence the bearings got rough......99% the bellows got teared, allowing the grease to spill out....
