Hid Kits
ujamil
Iv installed my 6000K hid kit, but one side seems to be brighter than the other; or should I say, it seems as if 1 light is facing down and 1 is in centre position. Im not sure why this is. Any suggestions?
Regards
The light on the driver's side isn't as bright as another one. It is faced a bit differently so you'll see the "edge" of the road better. It's same with halogens, but maybe as the light wasn't as bright as xenon you didn't pay any attention to it...
Post some pic, it will be a lot easier to say then!
Best regards, Alex
You cant really tell by pik, but here goes... And also, the passenger side is the one not as bright.
I see it I think. This is not caused by what I thought it is... Maybe there's some problem with the levelling, maybe the
mechanism which is levelling the lights when you roll the wheel inside your car is stuck on another side? Or then something
went wrong during the installation and the levelling got wrong at that point? When you point the lights to the wall, is the pattern
pretty much symmetrical, or is the light higher on one side than on another?
Best regards, Alex
1 side is way higher than the other. If you look closely,(which you cant see from camera), 1 of the sides seems asif the light is facing down! i mean literally down :| chek the quik image i made to represent this..
So you mean only the bulb isn't straight? The projector and the projector's lens are symmetrical on both sides? Check that the bulb is connected correctly, maybe it's not fixed and that's why it's like hanging there. Or then it's just the wrong levelling, in that case you should go to your dealer. They will check it out and fix I suppose!
Best regards, Alex
Will get it checked.. Thanks =D Im getting it lowered within the next week or so aswell. Going to get the Toyota motersport springs. What do you think?
Regards
Maybe they won't offer enough lowering for your car with those big wheels, but you'll get some quality product. Why do you want TTE? They are much more expensive than many others!
Best regards, Alex
Which 1s do you recommend? I dont want to have issues with speed breaker/humps after lowering the car, dont want it lowered too much. Which springs would you recommend? How much were your H&R springs? Also, can you please send me a picture of your car from the side. I want to see how it looks.
Regards
  • Replies 91
  • Created
  • Last Reply
Top Posters In This Topic
  • Speed_Chaser
    37
  • ujamil
    33
  • wastedagen
    12
  • Auris 1.6 vvt-i
    4
I think 35 or 40mm will look great, feel great and you won't have problems. Especially if you'll drive carefully (not too fast). My H&R's costed me around 200eur.
Here's some pics of my car; first without lowering, second one with H&R -35mm springs
Here you go also some more springs to choose from:
Lowering springs
1. TTE (Toyota Motorsport, Germany) PZ439-E9723-00 http://www.tte.de/
about -30/-30mm
2. Tanabe http://rd-tanabe.com/
Normal Feeling (NF) or Dress-up Form (DF)
NF (NZE151HNK) -24/-23mm
DF (NZE151HDK) -38/-37mm
3. RS-R http://www.rs-r.com/
T470D -35/-30mm or -30/-25mm
4. Espelir http://www.espelir.co.jp/
Active Low Down
ST-807 -35/-40mm
5. TRUST (GReddy)
BL Comfort Down Springs http://www.trust-power.com/
TYG085 -35/-40mm
6. TRD (Toyota Racing Development) http://www.trdparts.jp/english/
Sportivo Springs Set
MS250-12002 -25/-25mm
7. ZOOM http://www.zoom-bane.jp/
Down Force
TO108001SDF -35/-40mm
8. C-one Motorsport http://www.c-one.co.jp/
CS4810-ZE150 -30/-25mm
Lowering springs
about -30/-30mm
Active Low Down
ST-807 -35/-40mm or -35/-40mm
5. TRUST (GReddy)
TYG085 -35/-40mm
Down Force
Thanks Alex. Unfortunatly I am unable to see the second picture with the lowering. Could you pm me the second picture please.
Regards
Lowering springs
about -30/-30mm
Active Low Down
5. TRUST (GReddy)
TYG085 -35/-40mm
Down Force
Regards
Dont worry. Managed to make it display. Thanks. I cant really see too much of a difference. How much is the front and back lowered by? Which of these springs would you recommend? Which are of best quality?
Regards
Here you go the rest of the springs, didn't manage to get all the pics in one post:
9. KW http://www.kw-suspensions.de/
Lowering Springs 25056032 -30/-30mm
10. Wietec http://www.weitec.de/
-30/-30mm
11. H&R http://www.h-r.com
29084-1 -35/-35mm
12. Eibach http://www.eibach.com/
Eibach Pro-kit 8271.140
-35/-50mm
I suggest you to go for some springs which lower the car symmetrically.
Front and rear same amount of mm. Maybe H&R, KW or Weitec? They have
good quality, they all are well known brands and the're not too low!
And yes I know, you cannot really see any difference between those pics,
as they've been taken from different angle etc... If there were two exactly
the same pictures, one had the car with original springs, and another with
lowering springs, the difference would be more recognizable.
So let's try this way: Look at the two pics below, they're both taken with
stock size tyres and lowering springs. Try to remember how do the stock Auris'
look and compare the pictures to what you remember. The space between the
wheels and the body is much smaller than in stock cars, and I can see it right
away, hope you too so this would be helpful :)
Best regards, Alex
Here's what I found:
This is without lowering I suppose
This is mine, with lowering :)
Seems like much cleaner look to me :rolleyes:
Best regards, Alex
-30/-30mm
29084-1 -35/-35mm
-35/-50mm
Best regards, Alex
I was wanting to lower the car a bit more at the back than the front, cos the front is ok i rekon. The back is that looks like a jeep. lol. I was considering the Eibach springs.check the attatched pik.
Regards
-30/-30mm
29084-1 -35/-35mm
-35/-50mm
Best regards, Alex
Do you have the 1st pik with ur 18" wheels?
Regards
-30/-30mm
29084-1 -35/-35mm
-35/-50mm
Best regards, Alex
Regards
Nope sorry :(
-30/-30mm
29084-1 -35/-35mm
-35/-50mm
Best regards, Alex
Regards
Nope sorry :(
Ok. No worries. If you can take a pik that would be great thogh =]
-30/-30mm
29084-1 -35/-35mm
-35/-50mm
Best regards, Alex
Regards
Nope sorry :(
It's winter here = no summer tyres for a looong time :D
-30/-30mm
29084-1 -35/-35mm
-35/-50mm
Best regards, Alex
Regards
Nope sorry :(
Oh yes indeeed.. No worries. Thanks anyway =]
-30/-30mm
29084-1 -35/-35mm
-35/-50mm
Best regards, Alex
Regards
Nope sorry :(
Would these be the correct springs? http://www.nengun.com/espelir/active-super-low-down-springs
Regards
Cannot say for sure. Would be best to ask xpyyy!
Best regards, Alex
Best regards, Alex
Alex, I went to a garage today to find out how much they would lower for ect, and the mechanic told me I should change my shock absorbers too if I want to change the springs? What do you think of this??
Regards
Best regards, Alex
Regards
Yes, he's right. But it's not necessary with 35-40 lowering... Usually shock absorbers are changed because the original ones won't work properly with some springs which are lower than original ones. Original shock absorbers are designed to work on some special height, if the height is different, shock absorbers won't like it :D But you won't notice it whilst driving, it's only that you'll have to change the absorbers more often. They should last about 80 000KMs I think, but with lowering springs they will have to be changed at about 75 000KMs, not very big deal to me. Especially if you're not the one who is driving huge distances with the car...
Best regards, Alex
Best regards, Alex
Regards
Best regards, Alex
Do you know any kits that I can get. Full kits? Springs and shock absorbers.
Regards
