Clutch Problem
andye
hello everyone . can anyone give me some advice . my 2002 avensis d4d gear selection is sometimes difficult , sometimes the clutch pedal does not return fully to the top [maybe 20-30mm low] what can i check . cheers .
hello
it's deemed the clutch bearing is not returned back due to shaft has no grease. Or the pedal stroke might be adjusted.
Cheers/Igor
hello
Cheers/Igor
cheers igor . which shaft needs to be greased ? not sure on pedal adjustment either [ clutch is hydrolic ].
Possibly a faulty master cylinder. Has the clutch fluid ever been changed? You could try flushing it out with some new fluid.
hello
Cheers/Igor
hello
the shaft that holds the clutch bearing.
re pedal - check first with this shsaft greasing. i only deem with pedal adjusting. normaly it must to have adjusting thrust bolt that can be either screw in or screw off to reach a free strock of pedal. cheers/Igor
looking at the age of the car
I am inclined to think pressure plate faliure.
hi mate , clutch isn,t slipping or anything . pedal travel seems to reduce sometimes .i,ve bled the clutch and it seem to be ok for now , allthough i didn,t notice any air come out .
