D4d Glow Plugs?
Lusty
What will a set of new"glowies" cost for an 03 D4D?
Just the plugs,not the fitting.
Thanx
Mine, original Denso with fitting at Toyota garage cost me £ 120. I tried to find Denso online and it was not so easy. Bosch though are available. I would expect anything in the range 50-80. You can go for non-branded that would be cheaper. Depends on what you want.
Cheers.
You really serious about that? :unsure:
Here is the UK representative of Denso
United Kingdom
DENSO Sales UK Ltd
Building 1, Eden Road, Walsgrave Triangle
Coventry CV2 2TB
United Kingdom
T: +44 24 76843416
F: +44 24 76842521
E: J.Woodward@denso-sales.co.uk
United Kingdom
DENSO Sales UK Ltd
Coventry CV2 2TB
United Kingdom
T: +44 24 76843416
F: +44 24 76842521
I take your point.
I had not tried the distributor as I am a private buyer and I took it for granted they would not deal with me. I was after online shops offering the glow plugs.
i changed mine MYSELF :D on my 2004 2L D4D T3X. it cost me £36 for a set of 4 NGK plugs. they didnt need changing even tho they never have been changed in over 94k!! i just changed them becos it was an easy job to do myself!! and it was only £36 quid.
you can get them HERE
Hi
How easy were they to replace, I have a 2004 Avensis Diesel Estate?
Cheers
It took me ten mins inc. the time to take the engine cover off!! There are 4 plastic nuts on top of the glow plug nuts. they just twist off as they are only finger tight. easy job. you just need a long socket as the glow plugs are long themselves.
