Help Please!
Rolla_SR
Hi I just bought an adapter so I can wire up my amp and 6'9s... been looking round the forum for that diagram which shows the out put for Speakers etc.
I need to find out which cables to cut...
...any help will be much appreciated.
Easy......
Search Yell.com for auto electricians and then ask them to fit it for you
Job done :thumbsup:
:P :lol:
why are you chopping wires? lol.......im going to presume you dont have 'pre-outs' on your stereo?
in which case run the high voltage conector from the rear speaker wires themselves, just extend. dont go cutting. at least that way its easier to put back to standard.
Are you running your speakers and amp from the original headnit or from an aftermarket one.... are they going to replace your rear speakers or are you keeping them both??
I'm keeping the factory head unit, going to disconnect the rear Speakers and replace them with the 6'9s on the shelf
disconnect the rear Speakers and connect it to them.... or if your going to amp them then disconnect the rears and connect the 6'9s to the amp and connect up the amp to the headunit.
disconnect the rear speakers and connect it to them.... or if your going to amp them then disconnect the rears and connect the 6'9s to the amp and connect up the amp to the headunit.
Yep thats the plan i just dont know which ones are the rear Speakers from looking at the back of the head unit.
