New Engine Noise On You Tube!
rambler
hi folks
i have a new engine noise on you tube for you to listen to if you would please
its a horrid squeeeel type noise,type in 'rav4 squeel' and you should find it,only last for 15 seconds
engine can be cold or hot,just happens when i turn it off
its worse on cold days though
any opinions would be nice
thanks
hi folks
thanks
Here you go mate..Just wondered if i could adopt this technique at my docs send him a youtube video of my cough :lol::lol:
Please wait a few seconds for Video to load!
The only things that slow down when the engine is turned off are the cooling fans (but only if the aircon is switched on) and the turbo.
Turn the aircon off and then take the inlet pipe off the turbo and see if it is louder.
thank you local hero again for linking vid on the forum for me,much appreaciated
anchorman, really appreaciate your advice....i used to mess about with cars years ago,but not anymore(they are just too complicated now,all computerised and stuff).
i prefer to leave it to a 'qualified' technician,and as car is still in g/tee i dare'nt touch it.
you folks on here are just so helpfull,with advice,thoughts,comments.
rav going into dealers on thurs evening to hopefully get replacement 'water pump' 'brake solenoid check valve',check out a 'grinding' noise on front passenger side brakes,(had new discs and pads fitted both sides approx 4 months ago).
also a sometimes sharp or juddery clutch on cold starts ,only from standstill in 1st gear .
collecting either a 'yaris' or 'aygo' as courtesy car to use during friday.......yuk
would love a courtesy land cruiser instead!
