I have a Lucida Estima on a 1996 plate and was wondering what wheel pcd and fitment it uses please?
I believe it is the same as a Previa which is 5 stud with a PCD of 114.3 offset is supposed tp be between 38 - 45 but I have 50 on my Previa and they fit fine.
Thank you mate. Does it share he same pcd as any other car do you know?
Take a look here http://www.carlsalter.com/old_wheel_fitments.html
HOWEVER here is the big BUT !!!. Your car weighs close on 2 tonnes and with the exception of the Previa's the other cars are much lighter. As such you need to consider the load index of the alloys otherwise you will end up with buckled rims in a very short space of time or worse end up in a fatal accident. I went through all this research when I was looking for alloys for my Previa and ended up getting some original Toyota alloys from a new shape Previa.
Also visit
www.estima-motoring.co.uk
The guys on this site are all Estima owners and will be able to give you info on which alloys they have used.
Thank you very much fella!
