Updating Gen 6 Rear Lights
vitzpower
Hi All,
One of my rear light clusters from the early Gen 6 GT4 has a leak and I have a small fish tank in my indicator :P
I am going to take advantage of this and upgrade to the later revised rear lights... Question is how do I get to the fittings that hold the lamps in?? Can't see any... just wanted to check before I start to remove panels unnecessarily.
Any help would be appreciated, pictures will be better!
Thanks in advance.
You need to take the plastic off surrounding the inside of the boot and you will see three nuts, undo them (10mm I think). the one nearest the outside of the car is a !Removed! to get at unless you take off the plastic that goes round the rear seatbelts.
With all three nuts off the light unit will pull out.
Thats it if I remember correctly ;)
Cheers, buddy! Just got to wait for the replacement lights to arrive :D
Yeah the late spec lights look loads better ;)
I think it took me about 45 minutes to do both sides and thats with not knowing how to do it either!!
