Headlight Problems Help!
schan
I am having problems with the headlights on my Prius. On the driver side headlight the dipped beam would not come on while the high beam is working fine, As it is the same bulb that operates both beams I wasn't sure if the bulb is at fault. I am not a very experienced car user can someone please tell me if it is indeed the bulb I have to change or could it be a fuse or anything else? Thx
Aye sounds like a bulb, cost about 7 quid and, unlike the Avensis ( my previous motor) about 30 seconds to change. No worries, ask in Halfords I am sure they will help with the fitting if you are unsure. B)
