Airbag Light On Dash Staying On!
essex-dave
hi boys and girls,since yesterday my airbag light on the dash is flashing any ideas how to reset or the reason for the problem.its on a 55 reg 2.2 d4d avensis.thanks for any help you can give
Its look like I have same problem. Is anybody had same problem please help ???
I just moved massenger seat little backwards and light just turn off magically. I really dont know why ?????? may be it was obstructing some sensor or something i really unable to understand.
Regards,
Dr Sam
Regards,
Dr Sam
Nope. There is a connector under the seat, so you must have had a bad connection. Also try clean the metal plates inside the connector.
Regards,
Svet
Regards,
Dr Sam
Do you mean the passengers seat. I think i wire for the side seat airbag came lose that's why the Airbag light came on and when you moved it it went back into place. I think you should locate the wire to make sure its plugged in correctly.
Sounds like your seat belt pretensioner sensor.
I haven't had this issue in the Avensis but had the same problem on a number of others cars I've owned (namely Renaults).
I found that moving the seat backwards and forwards made it stop/come on. When I had my car serviced I told them about it and they said they had fixed it. When I looked under the seat all they'd done was stick some electricians tape around the wire. It did the trick and never had the problem again. I woudlnt worry about it too much, but its worth mentioning next time you have the car in for a service.
  • 2 months later...
i have the same car,model and year with a flashing airbag warning light,the strange thing i disconected the air bag plug under the driver seat and then reconected it , :angry: it fix the problem for about a week then came back,still haven`t got to the bottom of it,have you had any luck?
Best to go carefully with the connectors. The technical manuals say to disconnect Battery and leave for a few mins before disconnecting connectors due to the risk of deploying the airbags! Never seen it happen but i know it wouldnt be a good thing if it did! :o
  • 6 months later...
