St185 Glonking Noise From Driveshaft
OZZY_C
hey guys, I did a clutch change which ment i had to remove the gearbox and i think i have damaged the inner joint on the drive shaft as I am leaking gearbox oil from the joint and when I drive it there is a glonking noise from the drive shaft area also if i full lock it to the left and reverse it sounds like it is just spining out. is it a case of just changing the drive shaft or is there somthing else it could be.
on a good note the clutch works fine all gears go in and it bites very well.
any info would be much appreciated.
Are you sure you have got the drive shaft pushed in and locked in place. If it didn't click home you will lose oil and get funny noises.
