Can You Help Me!
scott1212
PLEASE HELP IF YOU CAN PLEASE!!!!!!!!!!!!!!!!!
can u help me can i just exchange the front fog light lense or do i have 2 get a new 1???
my rear windscreen wiper isnt scooshing water wot could the prob b????
my reverse light isnt working tried fuses not the bulb n the light cluster seems 2 b fine wot else could b wrong????
PLEASE IF YOU CAN HELP PLEASE HELP
THANK YOU
not very clear on your problem here - surely if you wanted to change the fog light lens (i'm assuming it's cracked or chipped?) you would have to get a new (to you at least) one anyway?
blockage in the hose.
Not sure if an Avensis uses seperate pumps for front & rear washers but if seperate then perhaps the pump for the rear has failed.
have you checked that you are getting power to it when it should come on?
could be a break in the cable or a faulty switch?
THANK YOU
1. Not sure if lens is available as seperate or if you need a full light unit. Check with your local dealers parts department.
2. I presume you mean the rear washer, not the rear wiper, possible faulty pump or fuse? Can you hear the pump running? If it is, check pipework from pump to washer jet, check jet not blocked.
3. Reverse light switch faulty? Broken wire? bad connection?
