HI ALL MY CARINA Battery WENT FLAT AND WHEN RECHARGED THE IMMOBILISER WOULD NOT TURN OFF SPOKE WITH LOCAL TOYOTA DEALER AND THEY FAXED ME A DATA SHEET FOR RESETTING THE ALARM HOPE THIS IS OF HELP TO YOU
MODELS ALL
SUBJECT TOYOTA 5000 THEFT DETERRENT SYSTEM
GUIDANCE
IF YOU WISH TO JUMP START A VEHICLE (OR RECONNECT A FULLY CHARGED Battery ) TO A VEHICLE WHICH IS FITTED WITH A TOYOTA 5000 THEFT DETERRENT SYSTEM THE FOLLOWING PROCEDURE SHOULD BE FOLLOWED THIS SHOULD PREVENT THE REMOTE CONTROL HANDSETS FROM "LOCKING OUT"
BEFORE DISCONNECTING THE Battery
1) TURN OFF THE SIREN USING THE SIREN MASTER KEY. THE SIREN HAS ITS OWN NI-CAD BATTERY WHICH WILL CAUSE IT TO SOUND WHEN THE VEHICLE BATTERY IS DISCONNECTED UNLESS IT IS SWITCHED OFF.
2) REMOVE THE DOME FUSE. THIS IS USUALLY LOCATED UNDER THE BONNET IN JUNCTION BOX No2.
3) DISCONNECT AND REMOVER THE BATTERY.
WHEN RE-CONNECTING THE BATTERY
1) ENSURE THE SIREN IS TURNED OFF WITH THE MASTER KEY.
2) ENSURE DOME FUSE IS REMOVED.
3) REFIT THE BATTERY AND RECONNECT THE TERMINALS CORRECTLY.
4) TURN ON THE IGNITION.
5) INSERT THE DOME FUSE.
6) TURN OFF THE IGNITION.
HAZARD LIGHTS SHOULD NOW BE FLASHING
7) CANCEL THE ALARM USING THE REMOTE CONTROL HANDSET. THE INDICATOR LIGHTS SHOULD STOP FLASHING. IT MAY BE NECESSARY TO HOLD THE BUTTON DOWN FOR UPTO 15 SECONDS.
8) YOU SHOULD NOW BE ABLE TO START THE ENGINE. :rolleyes:
NB: REMEMBER TO TURN ON THE SIREN WITH THE MASTER KEY
AND IF THAT DONT WORK REMOVE THE LITTLE BLACK EARTH WIRE BEHIND THE GLOVE BOX BY THE ALARM BUT REMEMBER IF YOU DO THAT YOU NO LONGER HAVE A ALARM :unsure: PS: LOOK UNDER FUSE BOX LID FOR LOCATION OF DOME FUSE . REGARDS WAYNE
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
