How To Change Avensis Trip Computer From Kph To Mph
marama32
Hi All,
I had my horn fixed through the Airbag Squib.
The Battery was disconnected to allow the airbag to be removed.
On re-connection the trip computer now displays in KPH.
If anybody can advise how to change it to MPH it would be much appreciated.
Cheers,
Marama
what exact model/trim?
if it's the same as my 2007 TR with multi information display it's on p165 of the manual.
""vehicle must be stationary & key in "ON" position.
Press & release the "DISP" button repeatedly until "Setup Press & hold" is displayed & then press & hold the "DISP" button.""
should get a screen with
Clock
Unit
Exit
"Press the DISP button to highlight UNIT & then press & hold the DISP button. the distance units will be displayed.
each time the DISP button is pushed the display is changed. The unit can be set by pushing & holding the DISP button.
Push the DISP button to select Exit & then push & hold te button to change the display to the information display."
Hi All,
The battery was disconnected to allow the airbag to be removed.
Cheers,
Marama
It's a 2001 1.6 VVTI.
Unfortunately it's totally different to the 2007 model.
Thanks for trying though
