T-sport Compression..
P HUGE
hi,
After having some real running issues with the TS i thought i would do a compression test and the results:
dry test:
cyc 1 : 190 psi
cyc 2 : 198 psi
cyc 3 : 210 psi
cyc 4 : 208 psi
Wet test:
cyc 1 : 208 psi
cyc 2 : 221 psi
cyc 3 : 223 psi
cyc 4 : 220 psi
Results to me show problems on cyc 1 and 2. Whar should the compression be on these T-sports???
Low compression can be a number of things from Camshaft worn, bad timing, piston rings, pistons, bores but i know very little about jap stuff so any help much apreciated.
Thank You.
