Checkdis
bar
yo could someone check this out for me. http://www.kandn.com/instructions/57-0324_inst.pdf
i made a complaint because my induction kit stainless tube from throttle body to airbox doesent connect the box that connects to the back of
the original rubber tubing.ithought that this is the airflow meter and needs to be connected???
they sent me this that shows that once the kit is fitted that box is not attached???
help :unsure:
where do the 2 thin vaccuum pipes connect to , once you remove the resonator box then , cos the car wont run without them connected . also where does the air flow temp sensor fit . ??
the two pipes connect to the stainless piping like the original and the heat sensor fits to the coneis that what it is then the resonator box? so its ok to remove that box???i thought it was the air flow meter
it holds cold air ready to enter the system . thats all it does
