P1155 Code
dsedge
I recently had the EMS light pop up. I had it tested and it came back with the p1155 code for the bank 1 sensor 2 fault, so got that fixed but the light won't go out and when i tested it again it comes up with p1155 undefined code as the problem does anybody know what this means??
Hi mate - welcome to the club.
Please go back to your details and add as much as you can about your car.
The code points back to your oxygen sensor;
http://www.obd-codes.com/trouble_codes/toyota/
What do you mean by you got it fixed. Was it a new part with a warranty?
You probably won't notice any difference although it could be affecting the emissions slightly.
If you have changed the sensor did you reset the EMS with the code reader afterwards?
