ok i got a L reg toyota Starlet 13 gli.. I have changed my pads due to the warning light coming on in the dash.. All good and done.. only problem is the warning light is still stopping on still .. anybody else had this problem?
sounds like you might have lost a bit of brake fluid from the system. The warning light sensor is usually in the brake fluid reservoir. Check the level here and top up if necessary. Also could be the electrical connection at the bottle .
Good luck
Good luck
How stupid Am i,,, :unsure: so simple. Im sure my brain is going..
Anyway Thanks.. B)
  • 4 months later...
what are the possibilities of of the break light showing up when you have enough brake fluid in the tank.
i've been experiencing this for a week now.
any ideas guys?
:unsure:
