550cc Injectors
ajcluck
Hi all, i am wondering if anyone knows the maximum bhp you can run on standard fuel injectors? as i can only find upgraded injectors at stupid prices!
I think they start to max out at around 350bhp ish.
You could find a set of used bigger injectors.
Or try greenline, my mate got a set of 4 from there for his GTi-R and they were around £60 each for 700's, however there probably alot more now due to a poor pound against the yen.
350bhp would be the absolute limit imo. Would feel safer running around 330ish though
not totally nessesary TBH. im running 470bhp with blitz 850cc injectors and a walbro pump and stock FPR
you only need an after market FPR if you don't have a management system to control your fuel as otherwise you'll just over fuel. they are a good investment as they reduce the strain on your injectors as it allows the pressure in the fuel rail to be controlled more accurately
well i have just bought the greddy emanage ultimate, however i am still looking for reasonably priced 800cc injectors as the cheapest i have found is over £400!
Take a look on greenline.jp they are usually cheap but with the price of the yen just now I doubt that's still the case. Iirc rx7 injectors are 850cc's and just need a collar to fit
