Ae102 3sge Beams Redtop Swap Questions
Bean Bandito
Hello All!
This is my story.
Background:
My BEAMS redtop motor set is sitting at my friend's shop, waiting to be swapped into my 7AFE equipped 93 AE102 wagon at the end of this month. Unfortunately it is missing axles, motor and transmission mounts which has us scratching our heads. Through all of my searches, this is the only forum that has information regarding 3SGTE swapped AE10x which is a good start. However I'd like to know if this info will apply to my project.
Questions:
Pre-amble: My 3SGE BEAMS is equipped with a S54 5spd transmission. I can't confirm whether it comes with / without LSD without taking the trans apart. My first question is regarding axles.
1. Since I'm in Canada, I would like to know what USDM axles fit and if having an LSD or not makes a difference? On my AE86 I have LSD axles but does this apply to FWD?
2. Mounts - Can I use any S-series motor and trans mounts and modify as necessary or try using my A-series mounts?
Sorry if these questions seem trivial. I just want to be prepared when my car goes under the knife at the end of Feb!
TIA!
