What Size Bolts
Simple tech question - Does anyone know what size- Dia,Pitch and length the bolts are.
I am going to need some new longer ones when I fit my new exhaust system.
Until the new bits arrive I won't know how much longer they need to be.
Obviously I can't just take one of the existing ones to try and get a longer match because the car is also my daily driver.
I believe its an M8 bolt 75mm long with 23mm of thread. If your unsure of the length you will need I suggest buying a M8 threaded rod from a hardware store (like B&Q) and corresponding washers and nuts. Then you can cut it to size as the new exhaust is fitted.
Good luck!
Typical isn't it, my exhaust has turned up today, currently rain and sleet outside. gonna have to leave fitting it untill the weather improves. not lying on cold wet Brick Pavers to fit it at present.
Awww bugger, I want to see!!! Did I read somewhere you were getting a turbo to?
No SJ, what I said was the company I bought my exhaust from are developing a Turbo Kit- Not that i'm buying one.
Oh :( wishful thinking then. Please buy it when they do!! :D
Anyway, man up and get out there and put the exhaust on :lol: :P
