Removing Stereo From Mr2 Mk3?!
dazz
Hi, can anyone help, I have a Mk3 Mr2 Roadster (2000) and after coming out of the bodyshop, the stereo no longer works.
Think I need to remove the Sony WXC570R unit to check if the fuse has blown behind the unit (already checked Stereo fuses near passenger door!). Theres a plastic surround that doesn't seem to budge!
Any help much appreciated :D
hi ya. if its a zzw30 mr2 there is 2 grey plastic covers that have screws top and bottom then you shold be able to see the screws that hold in the unit. before you do this though make sure you check the dome fuse first.
