Front And Rear Wipers Broken
After the recent cold weather, I have found that my front and rear Wiper Blades do not work.
Since they ahve both gone at the same time I suspect a blown fuse, but I don't know which fuse to check.
I have found the engine bay fuse/relay box but there are many fuses/realys so I'm a bit stumped.
I don't want to go to a garage for something I could repair myself. Could anyone tell me what fuses to check.
Thanks in advance,
Matt
F15 it's a 20 Amp fuse man...
After the recent cold weather, I have found that my front and rear wiper blades do not work.
Thanks in advance,
Matt
  • 4 weeks later...
I have a 96 Carina and I've replaced the fuse but still no joy. I can hear the motor going when I turn on the wipers but the wipers still aren't working. Any suggestions? Is there anything else that would also rely on the same relay?
Thanks,
David
If you hear the wiper motor, then the problem is the linkage.
Thanks,
David
There is a nut on the underside of the motor which connects the linkage to the motor this has probably worked loose, easy enough to fix.
Good luck let us know how you get on fella.
