The central lock of my Carina E is not working at all. I checked the fuses, but they seemd to be OK. All other electric equipments are working fine. Please help, what is the next to check? Thanks!
Woul be helpful if someone could tell me where is the central door lock handler unit. I suppose it must be broken down. Thanks!
Don't know about the handler, but I had a similar problem and the answer was as easy as the drivers door lock needing some WD-40 sprayed in and the key to be vigourously thrown left/right a few times. I immediately heard the central locking working, saved me from a panic.
It has happened a few times now (over a few years), all during the winter. I guess the lock gets dirty from the rain salt dirt etc ...
Try it, I'll keep my fingers crossed for you !!!!
ML
If it doesn't work you might have a broken wire going in to the door.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
