Key Problems
leopard
Hello
The key to my mother's Corolla 1.4 (W reg) will not work anymore. When it turns absolutely nothing happens. It doesn't look bent or damaged but does seem a little scuffed at the tip. She is using the only spare which works fine, but I don't know what the problem is. Is it something in the steering column or just a worn-out key?
Thank you.
Sounds as though the ECU can't read the transponder chip.
As for what to do i'm afraid i have no idea.
Your best bet may be to ask at a main dealer... get an answer... then if anything needs doing go to an independant which will be cheaper! :lol:
