Stuck Fuel Average Mpg Display.
hissingsid
2006 Avensis Petrol T3X. Average MPG doesn't reset after refuelling. Any other way to do it?. Just out of warranty. Thanks for any help.
Mine is a 2002 and doesn't reset at refuel, only the range resets automatically. Manual reset is done by pressing 'trip' button until average mpg is on the display. Then, press and hold the 'trip' button until a beep is heard and average shows 0.
Maybe this will work for yours too.
Hope this helps.
(maybe the later ones like yours have something in the menu to set it to 'reset at fill-up'?)
Hope this helps.
It normally resets after fuelling. Holding in any of the buttons whilst Average MPG is displayed doesn't do anything.
Hope this helps.
My only other suggestion is to disconnect the Battery for a while. When the system reboots it may work again. Sorry can't be of more help. Have you looked through all the menu options?
