Avensis 1.8 Vvti 1zzfe
Abdul R K
Hi people,
I'm a new memeber so a quick hi to you all.
I've got an Avensis T4 1.8l vvti, of which the Big Ends have just given way. a common problem with these engines due to the Oil Pump being the root as well as the high Oil consumption.
I'm after a replacement Engine, but i'm too weary to go for a recon unit due to many having to regrind and polish the crank.
Does anyone know of any Engine yards thats are reliable and have a good reputtation??? If soo, i'd appreciate a response.
Take care all
Abdul
To Abdul R K,
Try Middlesex Rebores at Mill Hill roundabout, number in the Yellow Pages. Why not give them a ring & talk money regarding them over hauling your engine.
Why the concern regarding crank regrind!! If not satisfied try your local scrap yards, but you will have to find a runner to make sure no strange noises from engine when fitted.
Good luck, Beagh.
PS: You will get a better warranty from engineering firm than scrap yard. You may find your pistons may be at fault.
To Abdul R K,
Good luck, Beagh.
Thanks for that mate.
Will chek out today.
