Service Advice
Okay guys, just about to get a service, what should i get done and which fluids should be changed and replaced with what specifically? thanks
Do you have any service history with the car, do you what has been changed and when??
If not get the lot done for peace of mind, and maybe even a cambelt too.
Mo
Mo
Can you recommend what oil, brake fluid, gear box oil, etc to use? and anything i should look for? guy i bought it off did all the belts so its all good, only about 1000 miles ago
Any Full synthetic Oil, I use Mobile with Mobile 1 oil filter,
never really worried about brake fluid, I guess any dot 3 or 4 brake fluid,
gearbox oil, big recommendation with the MR2 is Redline MT-90. Youll need 4 QTs for a drain and re-fill.
I'd also service the coolant. Not quite sure on what type of coolant to use, but i know there is a recommended one for the MR2.
I'd also just check your power steering fluid, make sure there is no leaks and the reservoir is still full. My rack had a small leak, didnt notice it, then >!Removed!<
Thats all i can think of for fluids.
