Cam Tensioner
sithecelicaguy
hi im brand new to celicas but they are amazing cars ive just bought my first oneand its mint! being poor ive bought a non runner and i have an issue.
cam belts snapped and ive almost finished changing it
but the tensioner doesnt make sense (does it auto adjust???), its a twin cam 3sge 1989 so gen1 i think, the tensionor has no was of adjusting , there is no spring and the centre bolt on the wheel doesnt adjust either
its bizarre ive searched the internet and can find nothing the same, similar, but not the same, there seems to be 2 standard types of adjuster and mine does not match either, am i missing a trick? has something snapped offff???
the body of the tensioner seems undamaged and i cant find anything that would hold a spring on the engine casing nor on the tensioner body
And to really rain on my parade ( ive been lay on the floor of my garden for 3 days trying to figure this out) the belt will not fit and toyota have assured me its the right belt, i assume the tensioner is at its most unadjusted right now as it moves freely for around an inch up and down but not enough to get the belt on.
ive got a feeling this is something really obvious and simple but im not a great mechanic so any advice or ideas would be very much appreciated
thanks
Si
thanks
Si
Alright mate, ok firstly try find out exactly what model your celica is, from what you have put im guessing it is a celica st182 gti which is a gen 5. I had a look on www.fensport.co.uk and they have a hydraulic tensioner for your car which im pretty sure is the part you need. Put the belt on all lined up and once the tensioner is on you should then pull the pin on it and the belt should tension up nicely.
On fensport just go to parts, click on your car model and then go to servicing parts its under there about 49 quid i think.
Ive figured it out!
theres a pin adjuster under the cam wheel push it in lock it in place with a hex key slide belt on pull hex key out and tadaaah belt tensions! im so dim i knew i was missing something
thanks for trying to help anywho
you fancy coming doing this one cos i cant god dam do it! any ideas about tensioner pins cos this one seems seized solid ive beat the crap out of it all day and it aint moved
You mean the hyd tensioner i was on about? it cant be that solid i cant even suggest anything except pliers (obviously) or wirelocking pliers may be better if you have some.
i havent been able to move it 1mm with a screwdriver an extension bar, it must be broke, i read it should compress with 19 nm of force
hang on i take it you havent got a new one? think you are supposed to get a new one where the piston which you are trying to compress is held back by a metal pin then you pull the pin out when it is all lined up. I have never done it the way you are trying to do it although i do know it is possible to do but from what you are saying it does sound knackered anyway.
yeah your way seems to make a lot more sense!
www.tcbparts.co.uk may have one if u want a new one they are usually a touch cheaper than fensport
