Pillar Arial
hi
i have a Toyota Carina GLS (k reg) and the kids broke the pillar areal
what is the easiest way to replace this ?
I have tried to remove the fascia but i am having problems
  • 1 year later...
hi
it is easy
carefully remove facia with a screwdriver (don't brake clips)
remove radio (2 screws)
unscrew pillar aerial and cut the wire at the base
connect new areal to the wire using tape
feed new wire tru to the radio
and plug in to the rear of the radio
replace everything in reverse
wont take more than 1 hour to do
