Avensis Boot Re-alignment
murph_201
Hi, I have a 04 Avensis saloon and the boot is misaligned. One side to be raised more than the other and the gap on that side looks bigger than the other. Does anybody know how to re-align the boot.
Sorry and I know it won't help.. but.. have a rear-end shunt...
the last time I had my boot re-aligned the re-alignment wrote off the whole car..
hi
i am not sure but in case the boot has been installed then it must to have some allowance holes to be adjusted.
cheers
Thanks lads for thyr advice!
I took a look before but could not see anywhere to adjust it but will look again thanks again. B)
hello
check very carefully from inside - there must be some adjusting facilities as for each cover.
cheers/Igor
hello
cheers/Igor
Will do thankd Igor
if its twisted just twist it back. i work on the body fit process at the factory.
its just a matter of pulling it about till there is an even gap either side and it is level. if it the catches on the lock striker you can tap that side ways.
Nice one I will give that a try at the weekend and tell you how I got on. Thanks.
I tried that at the weekend and it works, still a bit out but did not have the time to get it perfect.
Thanks,
Murph_201 :)
if its within 1.5mm difference side to side its in std :thumbsup:
Strange one that.......I have the same problem but with the bonnet. Nearside slightly raised. will try a good bashing saturday morning and hopefully put it right!
