Cambelt
olly49
Hi To all
Could some one tell me when an Avensis cambelt is due.
53
petrol T4
regards
olly49
you're wrong - it's chain driven.
cheers
Petrol engines are chain driven and i believe the require inspection or replacement at around 100,000 miles?
Don't know about inspection, but the shoudn't need replacement at all. Belts on the other hand need replacement every 60.000 miles. aprox. to be on the safe side
Hello
I ve been told by MrT's mechanic - that the chain dies with the engine.
The only tension adjusting is required.
Cheers/Igor
