No Power To Glow Plugs
obboll
hi, i have the toyota granvia which has a kz-te 3.0 ltr engine the glow plugs are not getting any power can anybody help thanks obboll.
Check your relays, check your wiring. If you got a scanner, see if any fault codes come up as well.
We remanufacture the ecu's and a lot of the times we find it's the ecu at fault because it can't communicate.. but hopefully it's just a fuse or something :)
Goodluck.
