Avensis Gls 99
wahidhussain
It goes above it..
When you take the cover off you should see 2 foam covered lugs. You have to pull the bigger one out first and then pull the second one down by it's lug and then it will come out.
Have a look at the link below.. it will show you what i mean (scroll down to the bottom of the page ;) )
http://toyotaownersclub.com/forums/index.php?showtopic=56646
