Celica Gen 7 Gt - Advice On Security Devices Required
Felfy
Hi All
I'm looking for advice/recommendations/suggestions on how to secure my treasured Celica Gen 7 GT
I've already got a decent Steering Wheel Boot/Lock, but I want a bit more 'protection'
I've tried, (and returned) an Autolok Klamp-It Wheel Clamp - Extra Large
(Couldn't get the top locking bar to fit into the lower bracket due to lack of clearance in the upper wheel arch)
I've considered the Autolok Original Handbrake/Gearstick Security Device, but that looks as if it will not fit, due to the 'close' & slightly offset layout of the Gen 7 Handbrake & Gearstick
I'm also considering a fold-down or removable Security Post
So, can anyone recommend devices similar to the ones above, so I can protect my car from the thieving scumbags that pervade our country?
As a footnote, any good alarm systems, (reasonably priced), with Trackers & Immobilizers?
Comments & help appreciated
Highest Regards
Felfy
Update
I found this at Passion Automotive
Streetwise Easy Fit Road Wheel Clamp
Here a a couple of pics
Fully Closed
Fully Open
Fitted
(I've shown the Wheel Clamp with as much of the lock mechanism 'on display' - When fitted properly, I'll reverse the fitting to hide the lock assembly under the car)
It fits like a glove, is extremely quick to fit & is very visible
It also appears to be well made & very durable, but I'll be spraying the lock & pin mechanism with WD40 just in case
Highly recommended
Hope this helps anyone looking for a suitable wheel-locking device
Regards
Felfy
if you are looking at additional alarms clifford is probably as good as anything
some of the trackers you can get a lifetime subscription quite reasonable as well
Thanks Marty32
I am considering a Tracker & 'Clifford Alarms' have been recommended to me elsewhere
So I may go for a Clifford
Thanks again for your time & experienced thoughts
Regards
Felfy
