Do U Need Help With Toyota Faults?
toyota diag tech
hey guys
im am a toyota diagnostic technician with 10 years experience working for a toyota main dealer
i spend all day everyday solving problems on all models of toyota so any problems u need help with
just ask id be glad to help , :D :D :thumbsup:
hey guys
welcome, I think that you will be a very handy person to have around ;)
  • 1 year later...
hi my problem is my radio has stopped working, as i was driving the radio went off and ejected a cd since then i cannot get it to work either radio or cd . if i put a cd in it just ejects it. but i can hear a clicking from the cd player as i drive along which suggests it is turning. any ideas. thanks
hey guys
hi my toyota rav4 2002 hesitation/loss of power. no faults codes found in computer and from cold car is runs ok .
once warm the kick down facility and 4th gear do not operate 3rd gear is engaged with bang .transmission oil quality is good seems unburnt what does this sound like to you thank you
And yet that was the only post he made here.... :mellow: WHY LEAVE US!?! :crybaby:
And yet that was the only post he made here.... mellow.gif WHY LEAVE US!?! crybaby.gif
All mouth an bicycle clips.....I knew it would'nt last ;)
Kingo :thumbsup:
Hi, Welcome to the club.
All of my Toyotas are running fine, funny enough thats why I have Toyotas, because they always seem to run fine :)
!Removed! hell! You're right! I didn't notice that! I'm mesmorised by the nice font we have in the reply box :D. Much better than the last one. I want to keep typing!
I knew it was a year old hence why I had a pop at the fact he fecked off in his own thread. :P
hi
avensis D4D
i recently got a bad fill of diesel, (2 months ago)
the local gargae man took tank off, completly cleaned all parts.
however within ten days, the car cut out just as i parked up(since then it happens randomly every 3 days or 5 days.
garage man can't figure out the problem,
no engine management light comes on, no codes, he got some specialised person down from dublin with computers and stuff and nothing registering, he could see everytime the car has cut out but no reason as to why.
drives perfectly once on the road, and some days no problems when at idle rev
the only strange things happening:
sometimes the idle rev will go from .8 up to ~1.2 and back down, ususally when this happens, it'll cut out within the next 24 hours. or it will dip slightly below idle as if going to cut out but then settles again
no loss of power when driving,
black smoke sometimes, i.e today black smoke a few times(and wasn't revving abnormally) and has cut out three times this evening
disconnecting the Battery for ~20 seconds and she starts fine, although been stuck in traffic a few times, so just rev it up and floor it and the car comes out of it...this doesn't always work as soon as it goes back to idle rev, cuts out again.
a friend hooked up a hand held thingy and just revved the car in neutral, the MAF didn't register any change from going up and down the revs, i don't know if this is normal
i.ve been told it could a serious number of things and i can't afford the parts,
if you have any suggestions, i would really appreciate it
my local mechanic has checked all parts for dirt and has cleaned everything
thanks a mill
hope you can help
hey guys
Hi New to this , but have a problem with a 2002 Toyota Tundra 4.7L
I had to replace the Battery , I hooked up a secondary Battery to maintain codes.
I just bought the truck , with no owners manual.
Now the truck will not idle. My thought is to disocnnet the Battery to clear the computer
But I do not know if the radio will need a code ,once I reconnect the battery. Or if it even needs one.
The model of the radio is 16815.
Any thoughts would be appreciated.
Sorry, toyota diag tech is not here. And Elvis has left the building.
hey guys
Make a point of looking at the post date mate. :P He has long since gone, something that we have actually made a point of in this thread. :yes:
  • 3 years later...
hi as you can see :engine shot: ijust wanted to know if it would be straight forward to exchange an engine from a 2008 model into a 2007 model and what would you advise looking for ie should engine code on 57 model be the same or not any advice would be very helpful thanks
You've just dragged up a 4 year old thread, I don't think the author is here anymore
