Avensis 1.8SE
oRiNoKo
Hi guys,
New member here :D. I am the proud owner of the above car but would like to put a K&N induction kit on it. The engine is the 7A-FE, and there is a kit for the 4A-FE anyone help.
Failing that any performance enhancing suggestions would be appreciated.
I'm not sure about the performance gains, but the 4A-FE filter should fit as the standard air filters were the same. it's just the bottom end of the engine that is a little different.
I only changed the filter to a performance filter,but if its the induction kit that you want and the other one does not fit on k&n,green,pipercrossand hks all do a uni-fit kit and if it is more bhp you want i added a sebring sports exaust system with a superchip and got 8% more.I also fitted a 60BHP dry nitrous system which is the most you can go with in relative safety and flys you past any annoying sunday drivers also a spax one off damper kit helps you stick to the corners at more speed,hope that is some help.:D
