Coolant Leak From Bottle Cap
Dr Sam
Hi guys,
Finally I got my car back from dealer they have replaced the engine with recondition one. I'm driving it since last two days - everything is seem to be normal except when engine get hot, means after driving it about 10 miles, it gives knocking sound in 1st and 2nd gear when I stop on signals and start back again.
This is my first experience in diesel engine usually this kind of sound comes only when you have higher gears on slow speed.
any ideas what is could be??? plz help.
Sam
Sam
we have naturally lost the core of this problem due to age :)
The most probably this sound corresponds to poor injection.
Cheers/Igor
hi igormus,
You are spot on.
Today i took my car to dealer who did the engine replacement. and he detected it as a diesel nocking issue. and this is due to fuel injector problem.
Now they probably will replace the fuel injectors.
thank you so much for guiding me through.
will update you when get car back it this solve the problem or not :P
Hi guys,
Sam
Sam
Cheers/Igor
hi igormus,
You are spot on.
hello SAM
it is great
we're here to help even logically.
good then :thumbsup:
hello SAM
it is great
Today dealer send me update about their diagnostics, they found one injector seals is leaking, they have decided to replace all 4 of them.
Now I m little confused they are calling it Injector seals. I m guessing when they say injector seals they are refering it fuel injector ???? :(
Dont know much about these technical terms.
Sam
hello SAM
it is great
Sam
hello SAM
yea they refer to the injectors that spray diesel into the cylinders.
cheers/Igor
hello SAM
it is great
Sam
hello SAM
cheers/Igor
Thanks Igor
will update you when I get my car back
Sam
