Avensis Voice Activated Sat-nav And Radio
rogger
hi
i have just brought an avensis T4 53reg
it looks like it has the gear to activate the above by voice
i cant make it work
does it have it, or is it on a higher spec model?
many thanks
rogger
hi
i cant make it work
many thanks
rogger
I had a T4 2003 model once. Voice controls did not work on that model, think its for the T-spirit or as an added extra. I am sure someone else will clarify this if I am wrong.
Cheers
Mike
hi
i cant make it work
many thanks
rogger
Cheers
Mike
many thanks mike
rogger
hi
i cant make it work
many thanks
rogger
Cheers
Mike
agree with Mike
Mine also is not activated , as well
Cheers/Igor
hi
i cant make it work
many thanks
rogger
Cheers
Mike
agree with Mike
Cheers/Igor
It works if you have the colour sat nav. I have the turn by turn which works good enough for me but i still use the tomtom. If you have the colour one you get the microphone fitted on the above controls where the lights are and the alarm sensors. Then you can use the button on the right of the steering wheel to activate the voice command.
