Yaris Oil Leakage
galvani
Toyota Yaris 1999 yar 1 litre engine. Oil leakage exactly in this please. :(
Please tell me what is the problem?
Blimey, not a lopt to go on but.....
Worn rings?
Loose filter?
cracked sump?
missing dipstick? alright I'm getting desperate...anyone else?
Is the filter on tight enough? Is the seal seated properly? When was the oil and filter last changed?
Oil filter is ok, tight enough and dry. Oil and filter last changed a week ago. A suspect sump seal, but not sure.
I think that could be the problem.
Nothing too sinister by the sounds of it. Catch the oil and possibly change the filter and put the oil back in :thumbsup:
Catched already, many times, but oil still here after drive. Oil filter is clean and dry.
Normally the timing chain cover or sump leak oil. They join at the same place so sometimes a little hard to tell which it is. Clean it off and recheck maybe? Oh, and keep an eye on the level!
Ok a will. Thanks
