Fitting Anti Roll Bar Bushes
Coppertop
Just placed a write up on how with pics but it seems to have got lost mid air or maybe it was too big?
Problem was nocking from rear when going over manholes etc
Time taken about 30 mins
Skill level required I would say is Novice
tools Limited
Cost Cheap
So i wil try again and add info & Pics bit by bit
Antiroll Bar To be cleaned
Fitting New Bush
Cleaned & repainted Retainer
Job Complete
last shot location again look above light and you can see green anti roll bar retainer
Just got to grease and general clean up while I am down here
Cost of Parts £15.27 inc VAT from Toyota
Part Number T48818-20380
and they still knock cos the anti roll bar itself wears away , and new bushes make little difference after a few days ;)
First time i have heard of that .
I understood the rubber bush was to protect the metal and provide a absorbent wearing surface which reduced under the constant movement of the anti roll bar.
Obviously you must have had experience of this before on Celicas and i dont dispute your knowledge. Maybe you were unlucky and previous owners had not changed the bushes when they did need changing.
Either way the bushes were shot and are now fine, so i will monitor how long these will last. or the knocking to return.
cheers
Keith
  • 1 year later...
Hi
I stumbled across this whilst searching for such a solution, I don't suppose you still have the pictures because I have to do this for my MOT and they would be really helpful.
Cheers
Andy
SHARRU , ITS AN EASY JOB , 2 X 10 MM BOLTS TO REMOVE, BUSH PULLS OFF , PLACE NEW BUSH IN AND REPLACE METAL CUP AND 2 BOLTS .
  • 5 years later...
I'm having the front & rear bushes done on my 1991 T170 Carina2. The guy in the garage couldn't fix a price point as his 'how long...' software doesn't show it..!! LoLzzz
We will no doubt settle on 30bob each.... :tongue:
I'm giving him the parts.
TS
