Steering Problem In 94 Hilux Surf Ssr-x Kzn140?
Hi All, I would appreciate some advice, my hilux surfs steering seems as though is resisting to be turned, and the steering wheel vibrates as you turn. After a few kms of driving this goes away, but im frustrated to understand what it is, and how to fix it! Any help is appreciated. :(
Check the power steering drive belt. It may need adjusting also make sure the power steering pump has not come loose.
Thanks.....im new to all this, so where will I locate the power steering drive belt or pump in a 1994 toyota hilux surf ssr-x?
Make sure the power steering belt is tight, sounds like it's slipping then eventually grips when it gets warm due to friction.
KZN130 by the way. ;)
