Oxygen Sensors Rav 4 2.0
northern tiger
Engine warning light on dashboard came up; took to Garage & plugged into computer.
Diagnosis was "Sensor 02 circuit
Bank 2
Sensor 2
There are 4 sensors costing over £100.00 each - how can I find out which one it is?
grateful for any help
Northern Tiger
Hi.
There have been quite a few posts on the Air flow and Oxygen sensors of which this is a post I found that may help you.
If you type "senor" in the search box at the bottom of the page you should get heaps of helpful advice on your problem..
"sensors 1 are the top two and sensors 2 the bottom ones. Bank 1 is the passenger side (RHD cars) I'm talking about 4.2 Ravs btw."
best of luck
John ;)
So the garage plug in the tester tell you whats wrong but d'ont know where the sensor is ?. I would not use a garage like this, are they suggesting you change all four?
