Windscreen Washers
mr toy ota
Windscreen washer jets not working very well when operated, only a trickle of water comes out. I have tried cleaning the jets with a pin but this only worked for a few mins, is there a filter on the pump that will need cleaning and if so how. Or any other suggestions?
Maybe removing them and blowing them out with a pump or a set of strong lungs!! :D
Nah, seriously tho, pushing a pin in will only block them up even more, Try some very thin wire or soak them in hot water?? Maybe. :unsure:
Maybe check how powerful the supply is before entering the jets. If its ok, then definately a jet prob. If the supply is pants, possibly a blockage in the pipe or the supply motor filter is blocked.
take off the jets. take a spin down to your local garage, use the airline provided for pumping tyres to blow any dirt out of them... should do the trick.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
