What Diagnostic Cable For Auris ?
Andy SR180
I used to use Vag-com on my Leon and Ibiza, but what do I need to buy for my Auris ?
As far as I can see it might be a generic one like ELM327, but is there nothing like Vag-com
that can check all modules in the car ?
Andy
Sorry I have no idea what is out there. Our handheld tester costs about 3K :rolleyes:
Kingo :thumbsup:
i have succeed in scanning my auris with VagCOM 704 in the generic OBD mode
it reads engine parameters and DTC codes
can you please post more details about it?
i.e. it can read injectors values, air mass, ... ?
Cheers
Xana,
I still have Vagcom I will try it out later today and let you know.
Ok, hope we can get good news... :rolleyes:
Hi
Tried this yesterday, It reads fault codes ok and also logs various live info, not sure if it did injectors. there was quiet a few.
I will try and do some screen grabs for you. Here is a link from Ross tech that will give you an idea how it looks..
http://www.ross-tech.com/vag-com/tour/obd-2.html
Not sure it is worth buying a ELM 327 which i was going to do, this seems to do the same.
I did see this product which can connect to call control modules in the car, but costs 690 euros.
http://www.abritus72.com/commandertoyota.html
Cheers
Andy
