Clutch Slipping On Gen 6 St202
whitford64
The clutch is starting to slip - still drives fine normally, but it slips slightly if you put your foot down, I've only had her less then a week, didn't notice it on test drive!! nevermind. Any advice on is what needs to be replaced when the clutch slips, the clutch disc and Pressure Plate I know but do I need a new flywheel as well. Also is it worth getting a performance street use clutch like the Exedy Stage 1 Organic Clutch Kit, or is there no real differents in proformance?
i would replace the flywheel unless it was damaged mate that would only really happen if the clutch plate got right down to the rivits
i only put a new flywheel in my gt4 because the clutch is a nightmare to do and i never want to have to take the box out again
regards to performance clutch its up to really depends if your looking to up the power
