Studs
bar
The PCD is 5x100, don't know what it is on a Scoob though
Model - Celica >99 (Not GT4) Year - 90 to 99
PCD - 5x100
Offset - 35 to 45
Bore - 54.1
Model - Impreza Year - 93 to 99
PCD - 5x100
Offset - 42 to 50
Bore - 56.1
will fit if the offset is et42 to et45, if they are bigger than et45 they won't fit.. it should be marked on the wheel. Centralising rings will be required to make up the difference in the centre bore.
Model - Impreza Sti 05> Year - 05>
PCD - 5x114
Offset - 38 to 50
Bore - 56.1
(won't fit regardless of the offset)
