Looking For A Guide On Servicing Glanza V
Hi New to the fourm,
Looking for information on how to service my car like
1..Changing the spark plugs and what ones i should use
2..Finding the oil filter car to low to get under it :angry:
3..How much engine oil should i put in and what would be the best type
Basic information like this would be a big help and any other info on keeping my car running smoothly your help would be great.
I have a japanese imported Starlet Limited Edition with EP91 4E-FE Engine.100BHP, NON TURBO. I also have a full service manual for any starlet since 1989.
I don't know what type of engine in your Glanza V.
1. Reccomended spark plugs for 4E-FE K16R-U11 or BKR5EyA11 for 4E-FTE PK20R-11 or BKR6EP11 or go for any Iridium 1.1 Sparks.
2.Oil filter easily changed without getting under the car, even without any tools if you're strong enough, buy a new filter (better if original toyota) first and then locate your old one.
3 If it's a 4E-FE or 4E-FTE you will need 2.8 L of oil.
I would recommend Fully Synthetic oil, however some car mechanics DO NOT recommend it, so it's etrirely up to you. Castrol Magnetic 10W-40 is pretty much very good. Personally I am using TESCO FULLY SYNTHETIC OIL, 5w-40, doesn't cost a lot, which means I can easily change it every 3000-5000 miles or every 6 months [as recommended by the manufacturer].
Don't forget about the thermostat, radiator cap, air filter, fuel filter, fluids change, aux/cam belt change.
Tanx Paul JJ :thumbsup: this is usefull i have a 1.3 Turbo 4E-FTE Model EP91.
I'm not the best person in the world when it come's to engine's so this info is very helpfull. Any more info now that ya no my type of engine would be sound.
