Will This Sat Nav Fit My Toyota Auris 2007 T-spirit
waltonjon
this is the link for the sat nav that will fit the corrola but at the bottom of the page there is a picture of the sat nav fitted with the exact same interior as mine.
Here is the lnik: http://www.autodvdgps.com/index.php?main_p...products_id=232
Will this fit mine?
John.
Thats a nice bit of kit!
Image 18 (2nd to last) looks like an auris to me, you can clearly see the unique display.
I wouldn't want to say for sure tho. You never know!!
Get in touch with them.
http://support.autodvdgps.com/index.php?_m...eid=1&nav=0
...Image 18 (2nd to last) looks like an auris to me, you can clearly see the unique display...
Actually, that is E15 Corolla; not an Auris.
Hello Waltonjon, and welcome on TOC!
There's allready one topic about the Sat Nav/DVD systems on this forum... The unit you found won't fit your Auris as the size and model is a bit different than it should be to fit an Auris. Please read the topic I told you about for more complete info, you can find it here!
Best regards, Alex
u see, told you i could be wrong lol, that dash is soo similar tho isn't it?
Ive just measured the radio panel in my Auris.
The dimensions (aprox) are as follows:
Height: 12cm
Width: 24cm
So ive compared this with the unit in the link and it has the same dimensions.
Its only a few mm out though. Would it still fit?
No.
But if in doubt, get a hammer out :bash:
Over here in Oztraya (that is the correct pronunciation of Australia) we have a generic headunit across most toyotas, so you have the option of fitting something like this (more info here).
It's not a perfect match for the interior colours, and I'm yet to see one in a corolla/auris, but it is plug and play with steering wheel control support, so that is a step up over the regular aftermarket makes.
There is actually an Eclipse unit as a toyota genuine option over here too, so that is something else to consider. Link 1 Link2 Link 3
No.
Could i get the Auris facia on eBay? (type in auris facias)
Could i remove the facia off the GPS system and fit the Auris facia to the system and then fit it in?
this item fits corolla 2007 $ 2008 , if u like car radio dvd gps for auris, you need to look at the Auris DVD GPS ,
No.
